Spacers to lengthen handlebars...
Rottweiler
So this is a old post but here goes. I want to raise my bars also. Did not want to cut a notch. How about chrome wheel spacers?
They are 1.25 inch long and have .75 inside dia. could not find the outside dia. It looks close to 1.25 though. JP Cycles have them.
http://www.jpcycles.com/product/2200152
Will find a 3/4 inch rubber hose to fill the space between the 1/2 bolt and 3/4 inside dia. of spacer.
cdogg556
Why do you have to cut a notch? I have a set of 1" risers that I had on my 05 Bulldog and I never had to notch anything.
Bdawg12
I would like to get some 1" risers myself chrome that will work on a 08 k9
Sent from my SM-G920V using Tapatalk
Rottweiler
John, See post 45 - 47 of this thread. Post 47 shows why, the riser are made to fit around the bottom of the bars. Big Dog has a welded plate across the bottom for speedo mount. Even though Joe did a excellent job notching them to fit. Looks good but chrome can start to peel. Also they where $68 plus bolts. With these spacers there will be two flat surfaces mating together and total cost with bolts is $36 plus tax / shipping. I'm also replacing the rubber bushings with poly from WSW so the steel insert from the old bushing might work for inside these spacers. http://www.wildsteedworx.com/index.php?main_page=product_info&cPath=65_68_173_72_99&products_id=473
cdogg556
Mastiff bar spacers.jpgThere's no notching with these! I don't know if someone just made these or what, I bought them back in 2011 from a member here at the time.
cdogg556
These are some L.A.Chopper spacers that I stripped the chrome off and notched for my 04 Pit. Longer bolts were all I needed. 1 1/2" spacers. They have been on for about 5yrs?
Hey "Delicious", here's a bigger pic! :old2: And I gotta ask, what's up wif your name? Dont' know if I should be ask'n that but I gotta know! :oldsmile:
cdogg556
Yes I think someone made them, not sure where to by them. What I am planning to do should look the same. Just have one bolt going through to handle bars. 3 3/4 inch long bolts.
I am sure they will work as long as you have a spacer inside the spacers to take up the gap between the bolt and the spacer, when you get them done post a few pics!
Hahaha....my crew patched me in as Delicious, cause every time I cook for them that's all they say....lol
Rottweiler
It's been a while, but I put in the handle bar spacer on yesterday. Here are some pics.
Before Pics.
[/ATTACH] 2017 Big Dog Work.jpg IMAG1779 (2).jpg
Parts used.
After Pics.
I used the steel insert from the old rubber bushing for the space between the bolt and the wheel spacer. Worked Great.
cdogg556
Before Pics.
[/ATTACH] View attachment 48880 View attachment 48881
Parts used.
View attachment 48882 View attachment 48883 View attachment 48884
After Pics.
View attachment 48885 View attachment 48886 View attachment 48887
Looks great! I'm sure it feels better too! :old2:
