Speedo Disassembly
Bubba_BigDog
Redneck
Two questions:
1) How do you take the speedo apart? I've got it all broken down and have the speedo itself separated from the housing and everything... but trying to open it so I can see if I can fix the needle.
2) I've got the medallion speedo on the shelf, but haven't installed it because I also have the BDM Wires+ to install. Can it be installed without running the fourth wire as needed?
Bubba_BigDog
Redneck
Oh... guess it's a good thing I didn't keep trying to get it off then.
So if I can't get into it, then there's no way to try and fix the needle I assume?
Jwooky
No you can open them. They are crimped closed on the back side with the chrome bezel. If you take a fiber stick and carefully go around and around the rearward edge of the chrome ring it will allow you to separate the chrome ring and then you can access the internals. I have done it several times.
Bubba_BigDog
Redneck
Awesome... now what the hell is a fiber stick? LOL
