2002 pitbull console???
Derek1974
Thanks. Im looking for the plastic piece that it mounts into that runs the center length of the tank. Mine is cracking at the end near the seat.
chubs
One other piece of free advise, Don't tighten that rear bolt too much. You can see it start to get distorted and that helps cause the cracking !! I just run mine down till it doesn't slip back and forth easily, You'll see it start to deform pretty quick.:2cents::2cents:
Also make sure you have a washer on the bolt that tightens the plastic down
