Karata motor plate
bigkelk9
I feel like an ass.. But what the hell r yall talkin bout.. I obviously see the pics of which im not a fan of the style in the primary like that.. But is this what yall r talkin bout
bdm7250
I have a 3 inch Karata on mine , never an issue ,, you would think that as many people that want one Karata would make it a lot more available
Karata is pretty much a one man show, nothing gets done there without Jimmy. He is very old and not in the best of health, he will only do what he feels like doing and building belt drives for BD's is not on his to do list.
bigkelk9
I really like the looks of the Karata vs the Baker.
Baker is alright, but the Karata is badass..
JMO
Which one is which? I personally think that linda goes with the bobber or old school chipper style bike.. Not a fan on the K9, ridgeback, chopper, mastiff.. Maybe the mutt is just about the only bike I wpuld have that on.. Just a way to ruin a sleek clean lined bike.. Personal opinion of coarse
bdm7250
The wider belt is the Karata. Personal opinion, open primaries look awesome on any style, chopper or pro street..:2cents:
So your mounting this on the downtube?
Interesting.
Yes sir..., I never did like the oil tank feedline lower then the oil pump..., the oil pump shouldn't have to suck oil into it it should be gravity fed into it, although I'm going to have to put it in line ball valve on it because it's going to act just like a water tower all that pressure be pushing on that line and it'll fill my lower cases with oil..., that other set up with an under the frame I just didn't like that idea whatsoever I didn't want to starve my motor for any oil.
I'm going to drill out and retap the feed line in the oil pump cap so there will actually be a full 3/8 line of oil going into that pump you looked at fittings before it might be a 3/8 line but it tapers down real little for that little bitty 1/8" inch pipe thread.., so what do you think maybe 3/16 quarter inch hole on that fitting that ain't shit for oil delivery
I talked with this guy, his shop is right around the corner from Karata. He has everything but the motor plates and clutch. He says he has a bunch of stock but it just doesn't sell without the most important piece..:(
Yep pretty fucking useless without the Damn plate.
I'd say..hopefully I will get my hands on one someday, have a 3D scanner for work that I could scan the motor plate with to create a Cad model for the CNC.
Maybe someone on here might be doing some rebuilding this winter and can part with their plate for a few weeks.
Why not just get the baker? All set to go no messing around
Your asking this Again?
I don't like the looks of the baker personally neither does Doug. I'd only run a Karata I don't want a big ass bearing support plate just covering it up if rather run the wet clutch over the baker.
If I was going to run it Karata and no bearing support ... Longevity not the best route but I don't care ill just rebuild the transmission every 20k miles no biggie
Yep doesn't make sense to make stuff when it can be purchased ready to go and I don't think that wider belt is such a good idea for the transmission jmo
Correct...puts more strain on your main bearings so probably need to replace more often maybe 20-30k miles. Not really hard to do. Pressing out the main bearing is quite simple can be done without removing trans
