TapioK
You wise guys, explain to me why my engine did not blow out.
Got my bike from the shop, it has now new Compression Release valves. Was looking the old ones, specially the on that gave up. Basically it looks to be like a solenoid, on mine the inner part took of. There seems to be a bolt on cylinder end holding the piston part to the outer part with threads. On mine the bolt was missing, it had to fall in to the cylinder? Why didn't it break either a valve or a piston on it's way to the exhaust?
Rode the bike rather fast back home tonight just to see if the engine explodes
guy pulling next to me on exit said 60 miles at 115mph is not bad for a chopper. 6th gear might as well be a bit taller, now the rpm is bit high, yellow light on tachy looks like a warning light.
That Big Dog frame is made of rubber I think.
On the bright side the speedo was not fogged and needle was oddly staple! And LED light from Curtis is just brilliant
What is your experience with the frame? On mine crossing the centerline over say 95mph. sometimes causes this slow wave-like flexing. It is a bit un-nerving. I did replace the bushings on neck, it helped somewhat I think. What next? Front forks or rear suspension?
I'd say my 2003 is more stable on high speed, sure it has like 30.000 less miles too.
Can you see, I'm still a bit hyped
guy pulling next to me on exit said 60 miles at 115mph is not bad for a chopper. 6th gear might as well be a bit taller, now the rpm is bit high, yellow light on tachy looks like a warning light.That Big Dog frame is made of rubber I think.
