Make sure you have all the set screws out upper and lower. The forks may be stuck in the trees. I wrap the triple trees in painters tape, use a rag and tap the trees with a rubber mallet. Spray a little penetrating oil on the Lower triple tree and into the top triple tree where the forks seat into the tree. As you tap have a helper work the forks to break them free. Good luckthank you for the replies. I haven't had any luck figuring it out. is there manual?
