Bike won't start need help
Vin Cent
Bike won't start new starter and batterie all new wiring new ignition module new ignition switch runs good when it is running looks like it is chargeing when it goes to start it turns over get a bit and stops don't get it
Slick117
How long ago was all of the new stuff done? And has it run OK any at all since all of the new stuff was done...or did it start acting up immediately after the changes were made?
Vin Cent
All new stuff with in the past four months yes it ran after all that stuff was put on jest started this
pknowles
RETIRED
Have your battery load tested and if it is good it probably is a loose wire somewhere. There is a lot of info on this subject already posted. Hopefully it's something simple.
pknowles
RETIRED
What dose the pressure release do would that stop the bike grime starting
They relieve the cylinder pressure when you first crank it over. put you finger on the rubber nob in the middle of either cover and push down until you feel resistance then turn the key on and hit start the compression release should drop down.
If the new battery does not have enough cranking amps, you may need another? Or your CR's are sticking? A loose ground will give you fits as well. jm .02
What do you mean when you say it "looks like its overcharging?" . Have you put a meter on it?
If it just stops while starting battery is prob weak.
Slow down a bit Eric. He said it looks like its "Charging", not overcharging. Re read.
K..well fine let me rephrase my question what does a battery look like when it's charging? Haha..
My point is until he puts a meter on it we don't know. As you put could just be a weak battery.
Alexey
Very little information.
1. Remove the spark plug and check the spark.
2. What modules are installed on a motorcycle?
Do what I say and write the answers.
That was my first thought also.:oldlaugh:
But I have to agree with Alexey, ECH, RIP, ESC? and is the unit circut breaker or fuse protected? Give us more info, is there spark, does the ignition have power?
Vin Cent
While running the volts are at 13.7-13.8
Vin Cent
Yes the ignition has power and yes it has spark had it on battery tinder got it to start used a volt meter and while running volts are at 13.7-13.8 before it was like did not have enough power to start bike
Charge the battery with a charger and not a tender and do a load test on it, maybe the battery just needs a good charge since its new or there's a bad cell and a load test will determine that.
