All new stuff with in the past four months yes it ran after all that stuff was put on jest started thisHow long ago was all of the new stuff done? And has it run OK any at all since all of the new stuff was done...or did it start acting up immediately after the changes were made?
They relieve the cylinder pressure when you first crank it over. put you finger on the rubber nob in the middle of either cover and push down until you feel resistance then turn the key on and hit start the compression release should drop down.What dose the pressure release do would that stop the bike grime starting
Slow down a bit Eric. He said it looks like its "Charging", not overcharging. Re read.What do you mean when you say it "looks like its overcharging?" . Have you put a meter on it?
If it just stops while starting battery is prob weak.
K..well fine let me rephrase my question what does a battery look like when it's charging? Haha..Slow down a bit Eric. He said it looks like its "Charging", not overcharging. Re read.
That was my first thought also.K..well fine let me rephrase my question what does a battery look like when it's charging? Haha..
My point is until he puts a meter on it we don't know. As you put could just be a weak battery.
While running the volts are at 13.7-13.8K..well fine let me rephrase my question what does a battery look like when it's charging? Haha..
Very little information.
1. Remove the spark plug and check the spark.
2. What modules are installed on a motorcycle?
Do what I say and write the answers.
Yes the ignition has power and yes it has spark had it on battery tinder got it to start used a volt meter and while running volts are at 13.7-13.8 before it was like did not have enough power to start bikeThat was my first thought also.
But I have to agree with Alexey, ECH, RIP, ESC? and is the unit circut breaker or fuse protected? Give us more info, is there spark, does the ignition have power?
Charge the battery with a charger and not a tender and do a load test on it, maybe the battery just needs a good charge since its new or there's a bad cell and a load test will determine that.Yes the ignition has power and yes it has spark had it on battery tinder got it to start used a volt meter and while running volts are at 13.7-13.8 before it was like did not have enough power to start bike
, you need to have the battery load tested.
