fright night with no lights!
Yes it's Same one in the link, still in the Wire Plus box.
I sent a private message with my PayPal I can ship it out tomorrow.
The BIG problem with a 3 way switch is IF you go to a bar at night in town and forget to turn on your lights you will see blues and jail... Ask me how I know. A 2 way on/off is a better way to go IF you put in a LED headlight which doesn't take much juice when starting.
I have a prestart acronym that I use codename K.I.L.L.
kickstand
ignition
lights
leave
I always ask myself did you kill it? a little habit I picked up when I used to night race years ago. happened to actually see a guy who forgot his kickstand leaving an outerwear bike shop in Pittsburgh and man, did he ever get effed up. the guy quit riding after he got out of the hospital. it caught a seam in the concrete in the middle if a turn, kicked up in the air and tossed him before a long skid......
but back on point I like the fact that initial draw from a head light doesn't affect a 3 position ignition. since this seems like the problem and I have identified the one that is there right now
http://wire-plus.com/WP148--3-Position-ignition-Switch-_p_140.html
I will probably get another. what type of LED (part number) is preferable?
kickstand
ignition
lights
leave
So let me ask did you pull your headlight and check the harness to see if it melted?
no, not as yet. the only reason was because all of the running lights went out at the same time. with that said, I am going to guess that it could still be the problem. been on the clock 2 weeks straight but will investigate all possibilities on Saturday or Sunday. when I go to start it or just turn the key, the rear lights come on weakly for a split second and then nothing. thanks for the suggestion though. I will add it to the short list of possibilities!
well, fellow big doggers......it has been some time since my last post but I have a short and I was wondering what upgraded headlight harness I should use (ceramic) and where I should look to get one. will need to order asap. suggestions?
as always, thanks! guys!
R
BadDawg Bill
R
I think Curtis has them and he will ship fast.
ok but which one? the link or the one in the pic?
Unless you wanna take your tank off go with the WSW one. I don't know why you'd go through all the trouble to take a tank off to put a new plug on.
I had the WSW plug on for years I just removed it for a new one but the old one was fine.
