loose tail light assembly
bscott
Hello,
I have a loose tail light assembly on my 2003 chopper and was hoping someone could help with instructions on how to tighten it back up. It is the right rear tail light and I'm assuming I need to pull the LED board and there will be a tightening nut in the housing but just wanted to make sure. Thanks in advance for your help
Little-Boo
Pop the lens out, pull out the guts (light) and use a box end 1/2 inch and tighten up. If you can find the bolt on the inside you will have to take the strut off. The bolt might be between the fender and the strut, or look and see if there is a bolt between the tire and the fender going towards the light housing and tighten it up. I don't have a manual for 03 maybe someone will give you a better idea. But that is what I would look for.
Carlos :old2:
Conejo
Carlos :old2:
How does the lens come off? 2004 chopper
Smart ass?? Not an answer?
Doing an introduction and telling a little bit about yourself is only polite when joining a forum.
There is a little slot on the edge of the lens, put a screwdriver in it and twist, the lens will pop right out.
