Ridgeback tire pressure
tear tire pressure ridgeback
  • Total voters
    49
  • Poll closed .
Reaper
The book for the 05 at least says 40 in the front, and 42 in the back. I follow the factory recommended pressure.
IrishGuy
Yeah, I'm with reaper. I do 40 front, 42 back as is recommended.
My last rear tire only lasted 6,000 miles. The guy I bought it from was running 20 in the rear and the tire was already looking worn (only had 2,000 miles at the time! :eek:). Plus, it made the tire oblong. I pumped it back up to 42 and it lasted another 4,000 (and that was pushing it).
For me there isn't a noticeable difference between 20 and 42. Except that 42 will save you the hassle and $$$ of changing a tire every 3,000 miles. :zz2cents:
bdmridgeback
Low Down Chop Shop
I called Avon when I bought my bike and they said on the 250 and 300 tires, with a single person on the bike a minimum of 26 lbs. is needed to not cause weird tire wear. I Run 30-32 lbs. for the Wife and I on the bike and has worked out great.
Doesn't matter if its your car, truck, boat trailer, RV or motorcycle. I would stay close to the factory recommendations. They've already tried all the combinations. You'll get more milage and even wear from your tires.
Reaper
Exactly my thoughts as well.
Cuz
I myself run 32 rear 35 front. But if you dont know what you want to run I would stick to 40/40.
My tires have 12 thou on them. Im about due on rear for new one. Burning out at red lights could probably be the cause for that.
Laters
Cuz
BBChopper
Supports 2 Disabled Vets
If it where me I would run 5 to 10 under but keep a very close eye on it depending on air temp, also watch the wear!!!!!:D
Check it on every ride!!!
surferdude
dry docked
I keep it at factory recommended air pressure ... got 13,500 on the front and 9500 on the rear ... had to change out the rear for a nail at 4000 miles!!! Tread on the rear looks good ... front with 13.5k miles looks like I need to change it a few thousand miles from now ... fyi ... my clutch will need to be change out ... early 05's clutch carrier seems to be taking a dump ... !!!!:angry: :bang: :eek:
BBChopper
I would follow his lead!!!:hi:
Tim
Founder
Lifetime Supporting Member
Why did you get a rigid if you are worried about comfort? :roll::roll:
