Where to get parts?
Billy413
Work cancelled today due to rain so I want to change primary fluid and look at chain but I don't have new gaskets yet, can you reuse the old one? I don't want to pull it off if I can't. Normally I would wait till I had the new gaskets but wasn't expecting to be be off work.
cdogg556
Normally they are a 1 time use, they have a small amount of silicon adhesive to attach it. I have never been able to reuse, you could get some gasket material and easily make one:old2:
Make one? This ain't no 1996 ford truck were talk'n bout wanker! What kind advise is dat? :crazybitch: :oldconfused: Maybe in an emergency that's an option, he should just wait and do it right, no problemo's laters, right? :yesnod: :old2:
:agree: I have a feeling you'll be kickin yourself :oldbang: if you re-use a gasket and it starts drippin..
:agree:
cdogg556
:agree:
You wankers don't reuse your primary gasket? I had mine off an on probably 10x before it wore out. The 05+ you can reuse no problems it's a recessed gasket it's designed to be reused. The paper gasket on the inspection cover I've reused with just a dab of silicone.
Now an 04 is a different ball of wax would be replaced that's not a recessed gasket.
Billy413
I have an 05 ridgeback, I'll still order a new set but I was just wondering if anyone ever tried to reuse the gaskets, thank you for your input on this
Having one on hand is good especially since you don't know the shape it's in but on 05 you can reuse it absolutely. It will wear eventually.
Shit I've had that cover off so many times even took it off in a parking lot a few weeks ago. I say take it off do your work and put it back on if it leaks you need a new one. Not the end of the world just drain and replace gasket later. ATF fluid in the primary is cheap.
But then again a little oil leak doesn't ruin my day...some of these guys it's the end of the world..
Since this bike is new to you and not sure what's been done...While you are in there I very highly recommend taking the clutch hub nut off and cleaning it up and red loctite with 150-160lbs. This is known to be under torqued and will cause all kinds of problems.
The clutch hub nut is left hand thread.
Search the forum there's how tos and service manuals available.
Billy413
Searching now so I can take care of that, thank you and everyone who helped with this
I also reuse my primary cover gasket but I thought he was referring to the inspection gasket only. He didn't say he was taking the primary cover off, you guys read too much into this. However if you do remove the primary cover and replace the gasket your gonna have some fun getting that new o-ring to stay in place.
pauly
X1
Paul.
