Belt slipping 06 mastiff
Big Daddy 72
Custom Street Rod Interiors & Design
Just started doing it, in first gear my belt slips inter hard accel. Does it need to be tightened or replaced?
Probably, just a tightening. Check your rear sprocket to make sure they are not worn to a point.
Brew
Check your belt tension. If it's good then it could be the belt or the pulley that's worn. Yeah, as Wright said...
Big Daddy 72
12,700 had 11,900 on it when I bought it back in spring. Talked to mr wright my belt is loose. Gonna try to tighten 1st. I'm gonna completely tear it down in a month so prob buy a new belt then.
bdm7250
13000 miles, shouldn't need a new belt, it should last for 50k plus.
Big Daddy 72
Na, you can tell it's the belt. Feels like someone dragging your naked ass over speed bumps when you twist the throttle in 1st. Not that anyone has drug my naked ass across speed bumps before......o_O
