desertdawg
I searched my manual and found no procedure on starter replacement. I then searched the forum but didn't find a procedure that seemed to minimize disassembly. If I can find a way to get around removing my exhaust and pulley cover then I'm all in. If this post describes a procedure already documented then I apologize. My bike, a 2008 efi K9 with original ehc.
DONT FORGET TO TRANSFER THE O RING TO THE NEW STARTER....!!!!!!!!!!!!!!
- Seat, battery, and side covers removed
- Remove VFI for access to EHC platform attachment
- Without disconnecting wiring to EHC, remove 3 bolts holding platform to battery tray and move out of your way.
- Without disconnecting wiring, remove 4 screws holding breakers to the left side of the battery tray.
- Remove the battery tray by sliding it up and out.
- I used a long extension with a round nose allen to remove the 2 starter attach bolts accessed from the right side by sliding in above the pulley area.
- I left the positive cable from the battery attached to the starter as it's easier to transfer to the new starter off the bike.
- reaching down through the top of the frame I pulled the starter from the primary and then fished it out as there was plenty of room to jockey it around.
- As I mentioned, I transferred the positive cable to the new starter and reinstalled it then reassembled the above removed items.
