Compression release valves
Try freeing them up with WD-40, I put a small slit in the rubber boot to stick the straw in, and you can feel when you have it on the CR shaft.
Joke•ster
Can you make them work manualy?? The battery is good but when I hit the start button a LOAD goes to the starter makes one revolution then fires up.
On another note this load on the battery affects my speedometer from working . FWI if the battery is stressed the (stock)speedo works inconsistently ....
heybaylor
pull the plugs, spin the starter check compression, disconnect the cr's do the same .
compression should be a lot
lower with the cr's hooked up
the speedo will screw up when the batt voltage drops below about 10 volts
Marky-Marc
What you are describing is almost the exact same thing someone else had....one release would work, one wouldn't intermittently....it ended up being his starter...check your amp draw on starter....anything over 80 amps is not good.
And you can push them down manually as well....
Joke•ster
Correct the battery hits 9v .during load .
Why the starter? Not the bad CR.
I will be rebuilding the starter with Curtis when he does that again
