gas coming out air cleaner
brian9094
2016 k9 124cid super G carb I changed the intermediate from #31 to #33 runs good in low rpm I also changed main jet from #76 to #80 and now blowing gas out carb on full throttle help!!!
SMCT
Regardless of the jetting, gas really shouldn't be coming out of the air cleaner. You mention "under full throttle" so your obviously moving. I would venture to say that it's an air cleaner design flaw that is creating a siphon effect. It's no different than not blocking the back of a hood scoop off. It will siphon the fuel out as air passes over the air horn.
chubs
Exactly! I, stupidly once, tried to ride with a fountain pop sitting in my fork bag. :drool: BAD IDEA!! :oldnono: The faster I went, the more pop got pulled up and outta the straw. (had the stickiest shirt and pants crotch ya ever seen) :oldeek: I'm thinkin you are right about the siphon thing!:yesnod:
Matheny 514
I agree gas should not be coming out of the air cleaner.
Very possible, but I can't help but notice that there is no complaint of this specific issue before Brian9094 changed the jets. However, there could be a design flaw which is made worse by the increased fuel ratio therefore causing this. Or simply too big of jetting.
Brian9094 let us know how the #78 does.
