What milage you getting on your motor
BadDawg Bill
You know when S&S builds a motor or Baker builds a trans they put their money where their mouth is. I don't know why they both let BD build their parts and put in cheap bearings/parts but they did and I suspect they now regret it... My 107 S&S motor (S&S bought) was still strong at 212k miles which says a lot. My Revtech 6 speed was still going strong too. When I read about you guys having to rebuild a trans or motor with less than 15k on them it makes me sick. You spent good money for a quality product you didn't get. My dog is doing good at 22k but I worry all the time about it.
jska2636
212k miles wow?
jska2636
212k miles is that a typo?
BadDawg Bill
No it's not a typo. I built the bike in 1996 and bought the 96 CI motor direct from S&S. I updated it to 107 in 1998. I replaced the head gaskets at 180k and that's it. I sold the bike to my friend and he's still riding it today. I suspect it now has over 250k on it. I replaced 3 spedos in that time and kept a log.
jska2636
212k Thats insane, iv never heard of any motorcycle lasting that many miles without any major motor work impresive..i pray mine goes that long!
BadDawg Bill
Saw 5 Shovelheads at the Cabbage Patch today. One had just 1 side of the gas tank on it and it was the right side. 1966 The only year Harley made the petcock on the right side. He said the first spedo quit at 112k miles, the second at 92k and this one stopped at 87k 5 years ago so it was well over 300k. He said it has never had any work done on the motor or trans. The bike looked good and had the solo seat with the grab bar on it, kick start only. Too cool! Oh, and he was older than me....
Cool wish you got a picture! Shovels will run forever !
My next bike will be kick, need to build it just need the cash
vej
I've had every conceivable issue there is go wrong with my 08 mastiff.... I have 64k miles on it, and it would be twice that except for the down time.
- Was one of the first to have the clutch pressure plate issue... baker has since anodized the pressure plate.
- Blew a compression release valve out the top early on
- 3 speedo's went nuts (now have a DD)
- 2 rear pulleys ate up (sand here on Florida), now have my pulley SuperMaxed so it should last a lifetime
The list goes on and on... and I don't abuse my bike, I ride it like a bike.... but the most recent events were:
- The cylinder base gasket leak. Since I had to remove the cylinders to replace that gasket, I went ahead and had the heads milled .030, and replaced the gaskets with Cometic gaskets - total decking should be about .053, raising compression.
And while it was apart, my cousin and I took the transmission apart to see why it was jumping in and out of 3rd... here's what we found:
http://bigdogbiker.com/threads/3rd-gear-skip-surge.76960/page-2#post-753201
ChopperJeff
What type of milage is everyone getting on the s&s 117 motor and or tranny before motor or tanny gives out or blows up?? Thanks
On my 2005 Chopper, at around 52000 miles, the engine needed re-boring. Then at around 53000 miles, one of the bolts inside the tranny got loose, then fell out, jamming the tranny gears which required several gears to be replaced. At 87000 miles, the rear head gasket started leaking. I sold the bike at that point.
Viking
Biker
30,000 miles on my motor and I have TP rocker boxes. I ride mine pretty hard. Transmission lasted 7000 miles, countershaft moved, baker knew they had a problem with the 06's and fixed mine under warranty. All good since then
TP Rocker boxes don't count, they'll last forever......
