Moespeeds
No faults on the high/low, but the blinkers are lighting. According to the Big Dog tech, my EHC will not diagnose, it just indicates what signals it's getting. Right and left signals light on EHC, Run lights, just no high or low. Apparently the ignition module sends a signal to the EHC to turn on the headlight when I turn the key, then sends an off signal to the headlight while cranking the motor. Not sure if you saw my other thread, but I jammed my ignition into my battery and that may have finished it off. I'd say it could be the hand control is bad, but that doesn't explain why I can't get a low beam with ignition on. At this point I'll try another EHC, not like I have $500 just laying around, but I want the bike running by Myrtle. If that doesn't work, or the EHC is backordered for an extended period, I'll change the harness/bars/controls after Myrtle, and just stick with my direct headlight switch for now. Right now it's not fused, what size fuse should I put on there? Wire looks to be 20ga, but I gotta double check.
