2008 BDM K9, (has no elec power)
Little-Boo
The 08 bikes do not have a cam position sensor. What you are looking for is the Crank Position sensor and that is located on the front of the motor. There are two plugs one is the stator plug which is a push in type plug and the Crank position Sensor is held in place by a small screw.
If you need a new sensor let me know I have a new spare one that I can sell you for $75.00 shipped
Carlos :chopper:
cdogg556
Carlos :chopper:
Ok, I was going nuts thinking where the hell is this cam positioning sensor at? I thought that might be the case but wasn't sure, thanks for the info Carlos! :old2: :cheers:You are the man as far as spare parts goes, :old2: shoot if Curtis ever goes belly up you might have enough inventory to keep us all going! :oldsmile: :oldlaugh:
Little-Boo
Almost, :oldlaugh: :oldlaugh: depending on what he needs are, Clutch cables, front ends, axles, bearing, light and control harness, lights, caliper rebuild kits, mirrors, forward controls, throttle cables, Drive Belt, swing arm, complete set of tins for 06 mastiff custom painted, kickstand, Chrome nuts and bolts, 06 Mastiff wheels, PSI Carb, S & S IST ignition, windshield bracket, Spare Tranny, shocks, stater. The list goes on, I need to stop before the wife see this post. :oldhardlaugh: :oldhardlaugh:
Carlos :old2: :whoop: :chopper:
cdogg556
Holy crap Carlos! :oldwtf: I was just kidding, :oldsmile: but obviously you are very well stocked, :yesnod: I mean you prolly could build another bike if you wanted to, :yesnod: I know if I could afford to, I would also have a lot of spare parts and bikes! :old2::cheers:
bikeone
Tried to demount Front light - think the bulb is gone bad.Low beam don-t work,jumps steady to high beam.
screwed out the small screw s (two) at the bottom of the headlight.
No moving at the front sheet before the Glass.
Gave some lubricant between lamp and ring.
What is to do to bring the front ring and the reflector out?
Want to change the bulb / mount a daymaker.
If you haven't had it off in a long time it's a pain. Use some rubber latex gloves to help you get a good grip on the beauty ring.
Good luck, and you haven't installed that Daymaker? I got you that almost 2 years ago! Haha
pknowles
RETIRED
If you can reach over or under the handlebars and grip the ring with the tips of your fingers with the rubber gloves you can get more pressure and grip. Should spin right off. Everyone should know that you have more strength pulling than trying to push on it.
You dont have to be a engineer or rocket scientist to get this done. Sorry for the late picture.
bikeone
Front light works till end of last year without issues - Told I will change if its gone bad. Lots of miles on the daymaker - little less to 2 Years it is storaged - looks like brand new -HaHaHa.
Last year i was vacated with housebuilding - moved in february this year. More than six months hard road - but its done
Seems like its going better forward for my lady. Hope she lets her nightmare behind and forget it any day.
Bike season starts for me first of April.
And a Bulb will not stop the first ride.......
:cheers: maybe we come together in June....:chopper:
Hopefully you can make it! Would be great to have you again!
The only one we get is Tapio from across the pond but he doesn't really count since he is in Florida half the time, although lately he hasnt been state side!
bikeone
Kept it storaged till i need it. Bought two years ago some spare parts because don´t like spend bike ridin Time with waiting for parts.
All parts are dry and closed storaged. Hope storaged daymaker is as well than good storaged old wine.......HaHaHa.
Try to have a open time window for June - but in moment nothin is shure.
Would be nice to see ya all again and hang around together.
For some good Steaks would be place too........
