Just loosen the nut and only back off the axle adjustment screw on the belt side, give the tire a kick and you'll be able to get the belt back on easy, then readjust the belt tension. You could use feeler gauges to measure the distance from the belt and tire and adjust it right back to the feelers.Yeah, staring at that big axle nut and burst into tears!!!
You should go get some lottery tickets, lucky dogGot Lucky again, it was sitting just inside the housing....... so I snatched it out the backside.
