Turn signal dash light
Fitzy
Hi guys i have a question about turn signal dash light, in Australia it is law that if one of your turn signals has a fault the idiot light on your dash flashes faster to let you know there is a problem on the big dogs this does not work does anyone know what i need to do to make this work i spoke to a shop and they want $300 plus labour to fit a module to the bike any ideas
Cheers
pauly
I'm quite sure that they would splice into your harness and install normal indicator flasher unit and since you have LED's
in your bike they would also put in resistors to simulate the normal globe current draw.
Just my thoughts.
Paul.
Fitzy
Just my thoughts.
Paul.
Thanks Paul i noticed your in SA do you have yours complied ?
pauly
Yes it was done by a dealer in Melbourne but I have since changed my harness controller and part of the wiring for DOC's .
Anyway I do not think that either of them have that feature.
Thinking about it a bit more they might splice in an electronic box instead of the old flasher unit .
Apart from the indicators flashing at higher rate when fault is present (never knew I was supposed to have it) the DOC's controller was a special order for Australian
requirements. (I have asked for what I wanted like indicators working independently from brake lights...).
Paul.
JeffM
Hi guys, i don't have a flasher unit anymore everything is controlled via the Wire Plus unit, prior to that A to Z imports did a spaghetti job and installed a flasher unit that fused and burnt out weekly.
If your running LED indicators your standard ECR should do all the flashing. I got 4 orange LED indicators from China on flee bay for $20 delivered removed the LED's and installed them with clear covers worked perfectly.
Where abouts are you Fitzy? Send me a PM.
Fitzy
Paul.
Thanks Paul
