Bike acting up !
Vin Cent
Got a 06 big dog k9 the other day was driving down the interstate doing about 70 and the bike jest started cutting off and on and then it jest cut off pulled over it started back up went about 2 miles and did same thing keep doing this then it would not start the terminals where loose got the terminals all bake tight went about 1 mile and the bike cut off again got truck and trailer got bike home went over bike battery charged and while running the volts at 13.30-13.38 took bike for ride did not go for got home cut bike off and back on no power tapped on key switch out power but would not start any Help. Thanks Vin cent
Brew
So when the bike cuts off, do you lose all power, meaning does your lights go out or do they stay on?
Vin Cent
Double check your terminals, take em off and clean each one then put em back on and tighten em down. Good luck with the scoot!
They all clean and tighten down I am thanking it mite be key switch not shore trying to get some other thoughts on it thanks for your help
chubs
You're probably pretty close with your thinkin! (I forgot to mention that possibility!) Good luck, and stay safe!
Its easy to check, unplug the key switch and jumper it.
My EHC failed the cold test, I wonder if your's is failing the hot test:oldconfused:
How to you do that don't won't to mass it up
Sorry, just being a smart ass, every time you turn around there's something different going wrong with the ECH, the cold test is suppose to be a real thing, the hot test is what I was being an ass about. I had a bad day:oldangry:
Vin Cent
All good I got doc's esc is there a way to test key switch thanks hope things get better
It has a JST connector inside the coil cover, if you can unplug it you could jumper the connector with a paper clip. There is a cable clip that holds the wire in place and you prolly have to remove the coil cover to get access to the cable clamp for the switch, If it is the switch I have used a 9N tractor switch p/n 8N36from Tractor Supply on my bike, the key cylinder fits perfect without any modification other than putting or splicing the existing JST connector to the new switch.
8N3679C $15.99
bdm7250
Similar situation happened with my bike, tracked it down to ignition switch. Got a BD replacement switch from Jeff at DOC's, a little more expensive than Ker's solution ($89.95, I just really wanted BDM key for my bike.While I was waiting for delivery of my replacement switch I had just put a toggle switch on so I could at least take it for a scoot. Good luck, hope it's a simple fix.
Vin Cent
Yes i am thanking it is the ignition switch I am hoping that's all it is thanks for the help
