fucking oil
Alexey
On this bike you should make sure correctly connected entire breathing system. I do not see in the photo, but I suppose that on this bike improperly tried to improve the ventilation system.
Marky-Marc
Ok yea it's definitely soaked... Would that also cause some to blow out of breather tubes by carb ? Kuz when I ride some accumulates there as well and oil definitely isn't overfilled it's way low.
FIRST thing I would do is CLEAN your oil tappet SCREEN...if it's clogged, it will blow oil out of the breather.....
Marky-Marc
Oil on your carb is probably coming off the filter while your ride it. Again, clean your tappet screen. Take it apart and see how dirty it is...if it's clogged, that's your issue....
Alexey
I do not understand anything! Write easier. I'm from Russia. You ask about the intake manifold? On the front head is the breather. This vacuum breather. It is connected to the manifold. He pulls the air. It is connected?
Mayer56
I literally purchased the bike a few weeks ago and noticed this the second day I rode it. So unfortunately I never knew any better
Marky-Marc
Alex, breathe in and breathe out.....it's 430 pm in russia now...have some vodka.....hahahahaha
Marky-Marc
Any smoke coming out of exhaust on startup? while riding? Color of smoke?
Alexey
Alexey, Mine has been like that for years....if you take the original air filter off, that hose just sits there......aftermarket air filters do not have a place for that breather tube....
I understand. But it should not leak oil. I'm just assume ....
Mayer56
Ok I'm totally lost now. I'm leaking oil out of two supposed spots the first pic is the two little tubes off the carb where I first noticed when riding. The second is the little filter you said was the crank case right. .. Is there another breather as well ? Or are we just talking about these three...
Marky-Marc
Just got off the phone with Justin (@Mayer56). This is a 107 and that breather filter/hose is ACTUALLY his lower SUMP BREATHER HOSE (117's do not have this LOWER SUMP breather vent/hose) after following the long hose down to the crankcase. 107's are built on a twin cam base, where as 117 are built on a single cam base....his top breather hose is also still there, those are the same, no oil coming out of that. Also, turns out, this bike has been sitting for over 6 moths before he bought it, hadn't been run. He is puking oil out of the sump breather tube because it has been sitting so long and a lot of the oil drained into the SUMP (remember your mysterious vanishing oil @Alexey? - same issue). He is doing an oil change, and cleaning everything, and then he will ride it until the SUMP has blown all the old oil out of the bottom of the crankcase and he should be good. He will check his oil periodically.
On that note Justin, if your oil level mysteriously starts to rise.....it's coming from the sump as well...keep an eye on it....
