Round box is your primary, left box (center) is your primary inspection cover.i
Here's a zoomed out pic its drippingg right before the kickstand.![]()
typo...I edited it....Also what box to the left ? It looks like one big box to me lol
That is your crankcase engine breather hose with filter.....Also what's the little filter I was holding in the other pic.
Marc, it seems to me, dripping with breather filter. During parking, it runs down the body of the primary and dripping on the ground. Rear breather closed filter. But the rear breather air escapes, and does not come. Probably, disconnected the front breather .... So, what did I tell you ... This is a modification of the ventilation system. hard to see. He has to make sure.If it's dripping right before the kickstand, chances are your drain plug is just loose or leaking.....
top line is full. bottom line in minimum.Ok one more question. Do you know how to read this dipstick ? It looks dangerously low of I'm reading it right. ? There's a line towards the way bottom and towards the top not sure which one the oil should touch but oil barely touches the stick.![]()
Alex, you are correct, I'm still drinking my morning vodka and didn't read. @Mayer56, if your breather filter is soaked in oil, you are leaking oil out of your crankcase breather tube and it is dripping down, as Alexey stated. If you've never changed the oil, I would change the oil and see if it clears up. If the wrong oil filter was used, as Alex says many many times to me, it will do that as well.Marc, it seems to me, dripping with breather filter. During parking, it runs down the body of the primary and dripping on the ground. Rear breather closed filter. But the rear breather air escapes, and does not come. Probably, disconnected the front breather .... So, what did I tell you ... This is a modification of the ventilation system. hard to see. He has to make sure.
Check your oil level with your bike level.Ok one more question. Do you know how to read this dipstick ? It looks dangerously low of I'm reading it right. ? There's a line towards the way bottom and towards the top not sure which one the oil should touch but oil barely touches the stick.![]()
Alexey, Mine has been like that for years....if you take the original air filter off, that hose just sits there......aftermarket air filters do not have a place for that breather tube....Rear breather disconnected from the air filter, and placed in the bottom of the gearbox. On the breather hose is installed a small filter. May be removed one-way valve and for this small filter.
