Sorry BWG56- its a 2006 not 2016.According to your profile you have a K9 2016, it is still under warranty and I would think the new Big Dog would take care of that for you. Did you call them?
I still think you have a wire mixed up![]()
You may just want to try a new battery as well if everything else fails. I've had shops test batteries, alternators etc and they all came back good according to their test, but we're not.Yes, battery was double checked and charged.
Brand new last year.how old is the battery?
You can jump start, just don't have the vehicle running that your jumping fromYou may just want to try a new battery as well if everything else fails. I've had shops test batteries, alternators etc and they all came back good according to their test, but we're not.
Older batteries don't hold the same charge as newer ones but will test okay. Big Dogs require a high amperage to start.
On that note: DO NOT ATTEMPT TO JUMP START THE BIKE! EVER!
WTF is boltage?that doesn't mean it's good check the boltage with a meter has to be at least 12.8 to even think about starting
is that something you need to hold the mirrors on. LMAO
I had to do it
I'm glad you said this. I was starting to get concerned. I hooked my K9 up to a car battery that was hooked to a maintainer. Never started either one, but was worried that I might had damaged something.You can jump start, just don't have the vehicle running that your jumping from![]()
You know, BOLT-age......bwahahahahaWTF is boltage?![]()
I had to do it
You are correct, now I'll offend someone again because I generalize...dammit, BUT, A LOT of people assume a jump start means a running vehicle.........I need more coffee again...or Lunch......You can jump start, just don't have the vehicle running that your jumping from![]()
Your control may have water in it. Take a hair dryer or if you have a forced air dryer, try that. Hopefully it's simple as that.[/Q
I believe that empty JST is for a kick stand sensor, not seen one on a Dog thoughWhat does the JST connector go to that has nothing in it, its right behind the heavy ground wire?
Also the ring tongue terminal by the heavy ground cable has electrical tape on it and it looks like a red wire under the tape.![]()
