Super G Carb Issues
cajunbiker
Bike had sat up for a couple of months, went to start it, turn over but will not start. Put in new battery, drained fuel tank & put in fresh fuel. Pulled plugs they looked fine. Pull the breather cover & determined there is no fuel coming from the vertical brass tube. Accelerator pump screw turned out 2 turns from seat. Any suggestions?
BadDawg Bill
The gas dried up and became sticky varnish. You should always keep the bike running and turn the petcock off and let it run out of gas before storing it. Now just take the carb off, take it apart and put it in a coffee can full of good carb cleaner for about 24 hrs. then blow it out, put it back together and it should be fine.
