R
RenoMoe
Guest
I came by an extra tool bag that I would like to install on the lower front frame. Are there any do's and don'ts or any tips on hanging this off the frame
Thanks!!
Thanks!!
Couldn't have said it better myself..:2thumbs:I have mine mounted in that area. Only thing about it is that it catches all the crud that the front tire kicks up. But that is a good thing I guess since it's not getting on the motor!!!
IM TO FAT TO BEND OVER THAT FAR:bang: .........HE HE
LOL :roll: :roll: :roll: :roll: I HATE it when that happens
Yup - it keeps that front motor mount area real clean and is my least favorite place to clean.I have mine mounted in that area. Only thing about it is that it catches all the crud that the front tire kicks up. But that is a good thing I guess since it's not getting on the motor!!!
:roll: :roll: :roll: :roll: :roll:IM TO FAT TO BEND OVER THAT FAR:bang: .........HE HE
I have mine mounted to the trees and resting on the headlight because I didn't want to block any air flow to the voltage reg or the engine but this may not be a big factor anyway but it also protects the front of the gas tank to some degree, however I just went through a procedure that I didn't need to if I would have thought a little before I mounted it. I just spent a whole weekend with a Dremel and wet sand paper getting out all the gouges in my upper tree from the rivets on the tool bag and yes, I do have the one with the chrome buttons but it was not these that caused the damage but it was the smaller ones that secure the bag together, who would have thunk it? They are so small but they did major damage to both my tree and headlight housing. I can't do anything about my headlight housing short of having it rechromed, but I did fix the tree. BTW I did find a solution to the problem if anyone wants to mount their bag to this location. I went to a fabric store where they have rolls of Velcro in black and about 1" wide. I bought a roll of the soft side of the Velcro (not the loop side) which has a self adhesive backing. I mounted the Velcro to the edges of the tool bag (covering all the rivets) and the the back of the straps in strategic locations. This worked out great and because the strips are black they are hardly noticeable and provide a very soft and durable barrier between the bag and the bike aluminum. It took me about 15 minutes to cut the strips and mount them, wish I would have thought of this before, could have saved me a lot of work.
Ended up replacing the headlight and will probably replace the trees next... :bang: Oh well live and learn..
