Dragonslave
I was out riding 30 miles the other day and when I pulled into the driveway and when the bike went to idle, I lost oil pressure. The gauge fell to 0 and oil light came on. While I was riding the pressure was fine according to my gauge, running about 25-30 psi @ 2500 rpms. I don't have any leaks, Oil level in the tank is per the manual.
Let me go back in time and explain the events leading up....
Over the winter I had the 90 deg return fitting (bottom fitting) break off into the oil pump cover housing. I removed the oil pump cover, removed the broken fitting, and replaced with new. Doing this of course drained all the oil out of the pump so during re-assembly of the oil pump cover, I had to fill the ball check valve side with oil and let it drain down to prevent air cavitation. Once I did this, I had oil pressure and all was well. Until after the 30 mile ride in the first paragraph.
Last night I pulled the spark plugs and began troubleshooting. I attached a known working oil pressure gauge to the fitting the oil pressure sensor is screwed in the engine. I tried turning the engine over several times to see if I could get any reading on the gauge and nothing. I pulled the oil pump cover back off and checked the outer gears of the oil pump. They seem to be working normally. They do not spin freely so I know the key stock is not broken on the shaft. I also placed the bike in 6th gear and rotated the tire to see if the gears rotated, and they do. So this leads me to believe the oil pump is working normally but I did not disassemble the pump beyond this point.
I removed my oil filter and turned the bike over and oil was coming out there so I know the return line is not stopped up.
I removed the oil feed line going from the oil tank to the oil pump and took my air gun to it a few times so there is no blockage there. While I had this line removed, I tried to turn the bike over while I had my finger over / near the pump intake and couldn't feel any suction / vacuum. Since my tank is below my oil pump (not gravity fed), should I feel a vacuum pull on the oil feed fitting when trying to turn over the bike? I would think I should feel some sort of draw or suction.
Any other ideas of what I could check? Possibly something in the engine itself? Lifters, Pushrods? I am not that knowledgeable of how the oil system works in the engine. I do have a manual with a map so I know how the oil is circulated.
