Bike won't start
Vin Cent
Before you try to start did you give the throttle 2-3 twists? or did you pull the choke up? 3 times on the starter will draw a lot outta the battery and if you didn't ride it for 15-20 minutes, it won't fully charge the battery back up
Yes I did pull the choke and give the throttle 2 twists but no I did not ride it just cut it off and tried to start it did not thank it would take that much out the battery let it charge and if it starts I will go for a ride thanks
I would just try one or the other, 3 twists or choke, it should fire right over. If not maybe change or check plugs:old2:
Brew
Get the scoot running and put a meter on your Pos/Neg battery post while its running and let us know what kind of volts are going to the battery...
Vin Cent
Jest put new plugs in started bike went for a ride came back did put meter in it while it was running the volts where at 13. Something to 14. Something turned bike off and started it back up pulled it in garage and put it back on the battery maintainer hope all is good :chopper:
:old2: and your cables are tight? right:oldconfused: :oldlaugh: just ckeckin
