I have a 04 Big Dog 107 cubic motor replaced the starter and Brand new battery also...it still just
Heather O'day
I have a 04 Big Dog 107 cubic motor I replaced the battery and the starter was rebuilt she ran great 1 day then went back to click click I was told to check the starter relay...well we're is that and what else do I check
Hi - may want to do an intro and stick around for the long term. I would recommend rechecking all connections first.
Sounds like a loose connection like dingo stated.
Like these guys said either you are draining your battery from a loose connection or a wire short.
Or your not charging you battery when the bikes running. maybe a bad voltage regulator. To see if this is happening but the battery on a charger start it up and you should have between 14-14.4 volts when bike is running. Anything less than 14 and it's not charging.
Marky-Marc
Your voltage regulator looks like the image below and is under the front bottom frame usually.....but it sounds to me like a bad battery......
Heather O'day
He's tried new starter, new battery!! Worked on the brain too!! He's always got his Harleys but, I got him the Big Dog and it's been doing this off and on ..So any info would be greatly appreaciated
liferider
Looking forward to retirement
It's a brand new battery !! It's not bought from Walmart either! I'm posting for my husband it's his Dog!! So he knows his shit!!! Just looking for some input!
I detect slyness, is Mrs O'day trying to get info so she can go ask Mr O'day," why don't you check the connections on the battery, the connections on the starter. Make sure their tight test for a possible ground to see if it's grounding the wiring harness under the gas tank which some models were prone to and look at getting a RIP EHC honey!"
Marky-Marc
I should've put Walmart in quotes...I meant if ANY battery sits on a shelf too long it can go bad. If he has the original EHC (brain), they suck a lot of voltage...battery won't fully recharge if not driven at least 20+ miles.....as @liferider said, it's probably a loose connection/short, only thing that should make it go clickety click click is not enough power....check voltage on battery when running-should be 14+ volts, if not running, battery should read at least 12 volts....
Heather O'day
No slyness! Honestly just looking for advice as to what else it may be!
