Marky-Marc
Coming from you, a big thank you and I didn't need a translator.....Not a puff of oil on startup, or as it idles and runs, nor at throttle up. That shows a well assembled engine. Good job. Yes, 'shake it down' as they say. Start from the front axle on up to the forks, then all the way back is check every nut, bolt, and screw for tightness before the shakedown.
