M Mike New Member Apr 15, 2016 #1 Wen I start my pitbull the battery terminal s melt . I'm thinking a short. Something. Any suggestions.
pknowles RETIRED Apr 15, 2016 #2 Your terminal seems to be loose.it's not making a good clean contact
francoblay1 The Spaniard Apr 15, 2016 #3 Mike said: Wen I start my pitbull the battery terminal s melt . I'm thinking a short. Something. Any suggestions. Click to expand... Check THIS out too.
Peckerwood Active Member Apr 15, 2016 #4 Happened to me last year, it was a loose connection at the battery, Check your ground,
Bowhunter Well-Known Member Apr 15, 2016 #5 As previously stated, loose battery connections did the same thing to my buddies battery.
M Mike New Member Apr 15, 2016 #6 Thks . I will chk an install with tight contact. On battery I got a 3 10 crank is this. Strong enough. ?
FrankBDPS Well-Known Member Apr 15, 2016 #7 have you washed you're bike recently? I was watching the wizard of oz last night and the wicked witch of the west melted when they threw water on her.
