405bigdog
Ok, I have an 05 chopper. No idea the brand of fender or struts, not factory unless they have been cut down. I have the Avon venom on it now and it's less than half life. So it'll be a few months before I actually replace it. Probably replace front at the same time since I can't find a matching rear. My thoughts and reading lead me to wanting a metzeler tire set this time. Metzeler seems to make a 260/40r18 instead of the 250/40r18. I have around 3/8" gap between the fender bolt heads now. So the question is does the metzeler run wider or narrower then the Avon on average? With only 5mm per side I'll have clearance. That's if they run equally true to each other.
