Nukeranger
Nukeranger
I bought mine over 10 years ago and it is not listed anymore. I can say that it will do any tire up to 360mm. I do my 305R70-16 tires with no issues. It is about 32.5 inches in diameter.Hey Hew,
Which changer do you have? They have the MC One and the Classic Model. I like the classic one but my only worry is tire cleareance is only 31.5" - Won't work for my Jeep Tires. I wonder if I can remove that arm support on the Classic model. Also the bead breaker clearence is only 10", wont work for the 300. Seems like they are working on hitch mounts and they will ship in Apirl.
"CLassic Model" http://www.nomartirechanger.com/Classic_Model_Motorcycle_Tire_Changer_p/tc-classic-a.htm
I just went to measure it and a 35 inch tire seems like the limit. I will say that my good friend and I changed tires with just tire irons and use the weight of the car to break the beads back in the 80's. So, with a little hard work, I don't think I would have a problem with any tire!
MY dad always told me, if you have a big enough lever you could move the world, however, no matter how long the bar is, your going to be putting pressure on the aluminum edge of the wheel, Rut Roh, and the tire changer of mine is 500# and you can pull it around real easy prying on a tire.
