The wheels have 2 hubs each that unbolt and the bearings should be removed and be careful not to build up too much plating in the bores, you will have to install new bearings with a press fit if your having the hubs plated also.
Yes having everything that is Billet done,
Front Rim
Rear Rim
2 front wheel hubs Plus Bolts
2 rear wheel hubs Plus Bolts
Rear wheel pulley Plus bolts
Front Caliper
Rear Caliper
Front forward controls (foot) Plus Bolts
Front forward control levers (foot) Plus hardware
Shifter linkage
Handbar control housings
Hand levers
Rear passenger peg extenders and offset
Cam nose cone plus bolts
Rear Brake Caliper axle Mount
Fender struts
Triple Tree
Intake Manifold
Unless you know a cheaper way of having everything chromed out. As of now without labor from the shop that I'll take it to for disassemble I'm looking at 2500.00 plus shipping
