k9bdm
First off I would like to thank everyone on this forum for help I needed with my rear fender suction cup marks. Rear fender looks good as new with wet sanding and 3M imperial hand glaze and buffing. Now I need help with another problem.
My front tire on my K9 was going low on me last year. I would air it up to 42psi and it seemed every 3 days it was down on the rim flat so I would refill it no issues. During the duration of a ride I never needed to add air (knock on wood). I didn't want to chance a flat while riding and have the tire get worse on these PA roads. Tread could have got me through probably 1 more riding season but I figure spend the money now and fix the issue. I bought a new avon cobra tire and took the rim and tire to a local Harley shop to have them mount my tire. The new tire was good and holding air. A few rides latter same problem is back.
I've read on here some people having the same problem with a little bit of junk being on the rim and when they mount the tire it messes up the bead. I filled the tire up today and sprayed the rim and found very tiny bubbles coming from the beam around the rim in different spots. The rim itself is not bent and shows no sign of damage. My thoughts were slim it but read that's a temp fix and shouldn't ride over 65mph due to throwing off the balance of the rim and so on. I ve also heard some tire shops can put a layer of a tar type sealent and remount the tire? Should I wait till the tire goes flat and try to cean the inside of the rim? Or wait till I take the bike in for insection in 2 weeks at Harley and have them try to re fix the issue? Or take the tire to an actual tire shop and have them do their thing with it since they should know how to address issues since that's all they deal with?
That was my problem a couple years ago.
sounded like a bomb going off, it stretched the rubber that bad that it didn't return to its size after it exploded, funny as hell. I don't recommend doing it indoors
