Hirter6Pack
Not Quite A Guru
I did a bad thing. I went to go visit my ma and pa on Saturday with the bike. When I got off the bike I left the key on for about an hour or so. Then I did a worse thing, I tried to start it more than a few times. Then I noticed smoke coming off the negative side of the battery post. After tighting all the connections I put a 10 amp charger on the battery for about a half hour and try to start it again. Then I noticed that the ignition module not coming on or flashing. The next day I brought the bike home on a trailer. Today I checked the cam sensor. Thanks to youall I been doing some studying. The cam sensor seems to be checking out ok. Then I started to look at the ignition module the four little wires going into the module. Red = 8 volts, yellow = 8 volts, green = 5 volts. Where am I losing almost 5 volts? So I think what I'm going to do is get a new battery and make sure that all my connections and grounds are good and go from there. So from besides me being a idiot what do you all thank?
How does it feel to be human?
We all make mistakes now and then. Just try to not make it a habit!
so now I know it's not the cam sensor or the ignition module. But I still don't understand why I'm only get 8 volts from the E.H.C
I thank Curtis said about 3 to 4 week after I order it.
