Unless the sensor has come loose for some reason, the timing should be ok. Has to be fuel or weak coil. I would start with new plugs, after you check to see if fuel is squinting in the intake.
I also seem to think it has to do with fuel, but am taking him at his word when he says he has spark, fuel and air......Have you checked the Petcock? Fuel is on...but is it clogged? I have seen dirt and other gunk get into the petcock and block it or not let the valve operate properly.
. I'm running Mobile 1 20-50 oil, about the same elev. as you 05chop, 6700ft. It's been in the mid 60's here for awhile and I sit it in the sun to warm it, and put a light against the case. My next step here in a bit is to check the compression. Thanks for all the help fellas, this shit is confusing, and it doesn't help when I hear bikes go by all day.
Wow, love this forum, so many ideas. So here's a little more clarity to the situation. I started the bike about a month ago and let it run for awhile. I went to start it about 2 weeks ago and nothing. Here's what I did: Pulled plugs and checked for spark which is good, zapped myself trying to shade it so I could see better. Pulled the carb cover and filter, gas squirts like a beast when I twist the throttle. I'm assuming that it's getting to the cylinders, might try chubs idea and squirt some gas through the plug holes, although the plugs were wet when I pulled them. Gas is good, treated with startron too
3 things to make an engine run:Getting good fuel, good spark, turns over, won't fire.
Replace spark plug wires. Mine did same thing last weekend. I also drained the gas tank. Got fresh High octane gasoline and added Seafoam Motor Treatment and it now fires up like its brand new.Well shit. I went ahead and bought a battery Marky it needed done, it cranked a lot faster and longer but still no fire. I pulled plugs and they were wet again, but I went ahead and dropped some gas in the holes. I'm not sure when the last time the carb was rebuilt, not in the last 3 years. The plugs and wires are 2 years old but with 2 hip surgeries i haven't rode a whole lot. Rode quite a bit this fall after moving back to Co. and ready to make up for lost time. I didn't get to the compression check maybe tomorrow. Thanks again all, I'll keep you posted.
Tom it's an 03 with a 107. Chances are it does not have compression releasesbefore you throw anything else at it, stick your finger on the compression release and see if there is any resistance on it. check them both. if they don't move, they may be stuck open. no compression.
