Jgroth41
I tightened them by feel ; )...Do you torque them John? I always just tighten by feel but am skeptical to over tighten.
Update..I set my gap at .035...Runs great but about the same as when its set at .038...Should i stay at .035 or go back to 0.38 ? Or does it matter ?.. Good hing is it hauls balls compared to setting it at .040/;; )I tightened them by feel ; )...
I prefer the chopper so to each their own just giving ya a hard timePrefer prostreet, Still love to see good lookin rides whatever they might be![]()
Personally I think between. 038 and. 035 on a stock motor probably splitting hairs but John is the guy that will have the data and experience to back it upUpdate..I set my gap at .035...Runs great but about the same as when its set at .038...Should i stay at .035 or go back to 0.38 ? Or does it matter ?.. Good hing is it hauls balls compared to setting it at .040/;; )
There was one differance..at .035 letting off the gas it did pop a tiny bit. (exhaust)I prefer the chopper so to each their own just giving ya a hard time
No. Been doing it for so long, I guess I earned the proper feel.Do you torque them John? I always just tighten by feel but am skeptical to over tighten.
NOT the plugs causing that..There was one differance..at .035 letting off the gas it did pop a tiny bit. (exhaust)
thats strange because when i put it back to .038 it doesnt do it. ; (NOT the plugs causing that..
I will keep dinkling around..thanks for all the help ; )thats strange because when i put it back to .038 it doesnt do it. ; (
good advice, lots of shipping tends to beat and bang on little bendable things.I recently bought a pair of Champion RA8HC on Amazon which are supposed to be pre-gapped to .04. They were actually less than .025. Definitely check the gap before installing.
I have never ever installed plugs without setting/checking the gap even if they have the cardboard tubes on them.good advice, lots of shipping tends to beat and bang on little bendable things.
... and adding some never-seize to the threads...I have never ever installed plugs without setting/checking the gap even if they have the cardboard tubes on them.
