1980 CJ7 . Spent last spring restoring it. Still have some stuff to finish wiring on the dash left to get everything working. Having trouble with the Speedo and temp sensor. Just replaced the temp sensor today that didn't help so now looks like I need to run new wires. The old PO hacked up the harness so I've had to rewire most of it.what year cj do you have? gotta love jeeps!
Guide coat, blocking it, 3 coats primer and then wet sand, damn. Whatever happened to wet sanding with 220, red oxide lacquer primer, sand down with 320, tack and lay 2 piss coats, color coat and then the shine coat, never had clear back then
