Fork Cap Removal
Dragonslave
Just wondering what everyone uses to remove the fork caps when changing oil or seals? I need to buy something before I get started on this job and would like to know what tool is best to use.
The Chrome one on the top you need a 1-3/8 socket. I put painters tape over the cap and socket to not scratch.
The actual tube cap just a good adjustable wrench. Loosen that cap before loosening the pinch bolts on the lower trees
Dragonslave
My adjustable is not large enough. I will need to buy a bigger one or a socket to fit it. Did the painters tape really help that much? I really dont want scratches.
So there is two "caps"
The one you can see is chrome and yes the painters tape helps. Dont use an adjustable wrench on that get the socket.
Under that nice shiny not scratched chrome cap is the actual fork tube cap. Currently hidden in the top tree! That you can take off with an adjustable you can't get a socket on it as it's just flat on two sides. Perfect for an adjustable wrench. You should have an adjustable wrench big enough for that cap it's much smaller.
Dragonslave
Gotcha! First time doing this job. Is the size socket I need an 1-3/8"?
:)If your just changing the fork oil ....just flip the bike over.
Ker has a winch to flip him over maybe he can try the bike? Don't even need to remove the damper bolts and get new crush washers that's genius !
