I had a similar problem once where the horn would sound and bike would die, ended up being my tag light wire pulled off the light board and the vibration would eventually allow it to hit the metal and short it out. Only noticed because I finally saw the light flickering. Not saying that's what it is but could be something shorting out!
It's a DTT triggering. Bike sits with key on, engine off... within so many minutes/seconds the horn is triggered. Can't be the switch sitting there in the on position. Bike runs and stalls. Loose key switch should have failed by now or loosened up enough to pinpoint. Make sense?Has anyone mentioned the Ignition Key?
Wiggle it around to make sure it does not brakes contact....
Yup, I am thinking a short somewhere as Twisted mentioned b4.It's a DTT triggering. Bike sits with key on, engine off... within so many minutes/seconds the horn is triggered. Can't be the switch sitting there in the on position. Bike runs and stalls. Loose key switch should have failed by now or loosened up enough to pinpoint. Make sense?
I have wiggled the key while the bike was running and it didn't effect the bike. The tag light was not working, thought that could have been the problem. I unplugged the connection and the bike still turns off.Yup, I am thinking a short somewhere as Twisted mentioned b4.
I don't know, I would say you are low on voltage and that VR should be a match to the Stator.
If you need a stock stator, I have a used one I also have a used stock VR. I put a Compu Fire Charging system on mine and still have the used set up. They have about 2 thousand miles on them maybe less. Let me know.Yes, we do!Do we have a "How To" how to hotwire bike and take EHC out. That would show whether the problem is around it?
Tapio
I am thinking I will have to replace my EHC also with a gen 2 RIP. let me know how the install goes. Curtis is testing my EHC also, BTW I am from Houston. Sugarland area,Sent the EHC to Curtis at WSW for testing. Micro Controller locked up and the EHC is toast. Just bought the new Gen 2 R.I.P kit that is a direct bolt in to the stock EHC location without any rewiring. I will let y'all know how it works out when I get in installed.
ArrrrghhhhhhhhToday I installed the R.I.P Gen II EHC kit. Tried to turn it over and the starter locked up after the third attempt. The gear from the starter got stuck and would not disengage. I went to remove the starter but it was cocked to one side and I ended up breaking the starter front mount. Since I will have so much of the starter taken apart I will do a full rebuild.
It will be another week before I am able to fully test the new Gen II EHC kit and will give another update then. While I wait for the part to arrive I will change the primary fluid, trans fluid, and clean up the area.
What was your experience like installing the Gen 2 RIP. Was it a true plug and play as it is represented. I am planning on installing one shortly and curious about the install time.Arrrrghhhhhhhh![]()
Do you have any pics? along with the 2 mounting screws there is also a 1/4" locating pin in the nose also by the rear mounting screw, Was that in there?Today I installed the R.I.P Gen II EHC kit. Tried to turn it over and the starter locked up after the third attempt. The gear from the starter got stuck and would not disengage. I went to remove the starter but it was cocked to one side and I ended up breaking the starter front mount. Since I will have so much of the starter taken apart I will do a full rebuild.
Starter front mount. After taking the starter completely apart, I noticed that oil had been leaking past the seal and oil was covering the interior parts. Glad that I found the issue now instead of 100 miles away from home. I will clean everything up and put it back together with the new front mount.Do you have any pics? along with the 2 mounting screws there is also a 1/4" locating pin in the nose also by the rear mounting screw, Was that in there?
