firefighter2347
I have a 2009 K9 and I'm not getting power to low beam. High beam does work when switched on. Checked plug, bulb and fuses and they are all ok. Any idea what else I should be looking for?
Okay, let me take a simple disconnect where I pull the main power connector off the EHC, disable said 5v system or the processor-box; turn key on; see if my 12v lights turn on; then switch to hi-beam and this is my drunk test I walk the white beam.The problems could be....EHC or wiring between the EHC and headlight. Someone correct me if I am wrong....hell...im just drunk.![]()
X2.This is why I switched to steedworx LED bulb, no current draw like the H4
