Same here CurtisRay doesn't know what he's hearing.
Shit he has a constant buzzing in his ears now.
I've used stock, Lyndall's, Dunlo, SBS they all make the same sound and one isn't any louder than the other.
Bzzzzzzzzzzzzzzzzz:lol:so.......... can we hear it on MP3?
Thats the little voice he hears just before he runs out of GAS like an AZZ!!!:roll:Ray doesn't know what he's hearing.
believe most of the noise is due to the drilled holes in the rotors. the rear makes the same noise, but you just can't hear it when you are going 75 mph.
Not exactly sure what or where that would b but it literally only makes the noise when i apply the front brake.It isn't the LED globe little cooling fan is it?
Paul.
Take the caliper apart , pop the pistons out , clean/flush, also do the master cylinder.cool thanks for the info, will replace when they are gone, its not loud or the end of the world was just curious.
I do think the stopping power of the front brake sucks though, it works but damn you have to squeeze like a mother.
I Have no problem doing this if it will help. I mean I can hit the brakes, and it works, but I dont know that it would lock it up? or what. it will compress the front shock some but to me, it stops like crap... but I am mostly used to motorcross, and crotch rockets...Take the caliper apart , pop the pistons out , clean/flush, also do the master cylinder.
put new dot 5 in there, gravity bleed, and you will have a great front brake.
