StreetHog
I wondered about the air bleed. I currently don't have any 60's but I did go with a 36 pilot and 80 main. Now it seems to be spot on and the midrange dead spot is gone. BTW...the aux float plug is still in. Seems to run fine now but what the hell does this do if I remove this plug????Typical transition between jets.... go up on the Air Bleed jet.... go to a 60.
No need to go up on the Inter jet?... I am at Sea level and with the 32 is just fine... you are higher so... you should go no bigger than 31/32... which it´s the recommended for the V&H exhaust... (and maybe 76/78 in the Main) but again... every bike is a bit different.
