bearman
......we are talking about the start sequence the absolute most force on that chain during it's lifecycle ..........
Not trying to start an argument but a 2 kilowatt starter would only impart about 2.7 horsepower to the primary chain. Now compare that with the engine output of over 90 Horsepower.
I will argue about the transmission being out of alignment which causes your inner primary to be misaligned which then would cause the clutch basket and ring gear to be misaligned......
Yes, this could cause a misalignment between the clutch basket/rear primary sprocket and the front primary sprocket, but not the ring gear and starter.
....Not to mention If the trans isn't square the starter isn't square either since it sits on top. Right? ......
The starter should always be square to the clutch basket and ring gear since both are mated to the transmission.
