DRBarnhart
Insert title here...
Another possibility... Have you changed the ignition module? And if so, maybe it's too far advanced.
Dennis
Dennis
Haven't changed anything. still stock.Another possibility... Have you changed the ignition module? And if so, maybe it's too far advanced.
Dennis
Mines stock also, if you are using a slam button, are you pushing the starter shaft/gear out to engage teeth in clutch hub? If so, this bang is hard enough to break the starter housing and starter mount and i don't think I would want my finger on it when it kicks.Haven't changed anything. still stock.
Don't have a slam button. I thought a slam button was to engage the starter when there is an electrical problem. Don't see how it relates to the problem we are having.Mines stock also, if you are using a slam button, are you pushing the starter shaft/gear out to engage teeth in clutch hub? If so, this bang is hard enough to break the starter housing and starter mount and i don't think I would want my finger on it when it kicks.
Will be waiting and wondering.I'm following this thread, I have the same problem and you beat me to wiring up the CRs.
Weather is supposed to be nice this weekend so I'd like to actually ride my bikes and I have a kids birthday to attend but I have a couple things on my bike I'm going to take a look at. I'll post here If I find anything suspicious which I think may be contributing to our problem. I just don't want to send you on a witch hunt, I'll do that part
I'm starting to think it might have to do with alignmentThat's not right holding out on us Eric, come on spill the beans, we can't wait till the weekend![]()
No... if you are using a slam button, are you pushing the starter shaft/gear out to engage teeth in clutch hub? .......I don't think I would want my finger on it when it kicks.
you would need a "clamp-on" ammeter to check the current draw. I don't think current draw of the CR's are an issue but the starter solenoid might be. The starter will pull something like 300 amps, so if the solenoid coil is pulling 30 amps, that's 10% and if your battery is only capable of putting out around 300, it could be a problem. Notice I said "A" problem (it might not be the cause of your problem) and "IF" the solenoid is pulling 30 amps.I think I will start checking current draw on my starter and CR's. If I can figure out how to do that. I believe checking the battery current when trying to start?
Coolbreeze:Don't have a slam button. I thought a slam button was to engage the starter when there is an electrical problem. Don't see how it relates to the problem we are having.
I think your on to something with A, its seems like the starter gear goes out but doesn't catch enough of the ring and slips off when the torque is applied.I'm starting to think it might have to do with alignment
A) the Starter ring gear not being properly shimmed to align the front and rear primary chain. And when the kickback starts it's generating torque through the slack in the chain and twisting the ring gear when the jackshaft is trying to recede and occasionally getting caught at a funny angle causing the "snap".
B)Incorrect Transmission shimming causing starter to be misaligned in primary housing.
I don't think b is too likely either, but possible. I just think it has to be very far out of spec to see the issue down the line.I followed the manual for tranny shimming to double check for proper shimming. So In my case I can rule B out.
Could said alignments be off if nothing has ever been taken apart from stock?
A) the Starter ring gear not being properly shimmed to align the front and rear primary chain. ......
B)Incorrect Transmission shimming causing starter to be misaligned in primary housing....
That would suck.The first 7 starters I went through were because of jackshaft breakage. It was determined that my inner primary case was cut wrong. The little hole for the pinion gear was not exactly correct so the jackshaft would flex, and break.
I agree with a misalignment of the chain you will get premature bearing wear. I also agree that the chain is more forgiving however we are talking about the start sequence the absolute most force on that chain during it's lifecycle there is a reason why it's doubled and that's to prevent horizontal movement I agree.Yes. Things come loose.
Not likely.
For A) A chain is way more forgiving about being misaligned than a belt would be. About the worst thing that should happen is premature wear on the chain and sprockets and eventually bearings.
For B) The starter ring gear is on the clutch basket, which is mounted on the transmission shaft, which is mounted in the transmission housing. The starter is mounted on this same transmission housing.
So no amount of shimming the transmission to the frame, or misalignment of the transmission to the engine, should change the alignment of the starter to the starter ring gear (unless the clutch basket is flexing).
