Engine rebuild
garyb69
Ok, so as most of you are aware, i've had new pistons, barrels, crank, main bearings and whatever else amounted to £3700 of my hard earned English Pounds. I have been told 500 miles and oil and filter change, then another 500 miles and oil and filter change. Is this figure set in stone? Your thoughts please.
I would agree with the first 500, but then I would go to 2000 or a year, I only put about 2-2500 miles on the Dog in a year
FrankBDPS
For sure do the first 500. Look at the oil closely and cut the filter open to see if there is metal present. Good luck!
john sachs
If the machine work, and assembly work has been done properly, I would say 200 miles with regular non-synthetic 20-50 oil. Then drop the oil and filter, switch to 20-50 synthetic oil, and let it rip.
This is what I recommend for my engine builds to my customers, and have NEVER had a problem.
John
francoblay1
The Spaniard
John
That's exactly what I did when Andrew came to Spain to do my K9. Very same recommendation. :old2:
MARV
Dino oil 100 miles
Dino oil 500 miles
Synthetic 1000
Just did this on a hillside build
