pauldeepsea
Have about 5k miles on the metzlers front tire is bald and thinking about going back to the avon tires. Not really happy with the metzlers.
Agree going to change the wheel bearings too. I get a lot of front end vibration past 90 mph. Lolwowwww those didn't last long..........![]()
How many miles? Been putting close to 500 per week. Sitting at apart 5 k on theseWow had my metz on for a year and have plenty of tread on them
Thinking wheel bearings may need changed??? Front tire is bald and I have some shake in the frontI put around 500 a week on them. About 7K on them now
Yes, I also did do my wheel bearings when I changed over to the metz...Thinking wheel bearings may need changed??? Front tire is bald and I have some shake in the front
Should have when the bike was apartYes, I also did do my wheel bearings when I changed over to the metz...![]()
And if you run 20 or 30 wt.When was the last time the fork oil was changed? After changing mine at 15K and seeing how disgusting the oil was, I have decided to change my fork oil every tire change and it made a big difference in the front end dribble/bounce
WOW, can't believe you are riding with that.
Should be the 30wt. Harley Screaming Eagle heavy duty is what I used, recommended by Andrew(Bigdogtech01)And if you run 20 or 30 wt.
Changed during the rebuild about 4k on the bike sinceAnd if you run 20 or 30 wt.
Idk but avon has a 15k warranty on their tires! Tried avon, metzler and Dunlop on the pitbull most impressed with the Dunlop elite but 2nd the AvonsPaul-does Kirk still send a free bottle of fix-a-lfat with every Avon on-line purchase?
