In need of someone I can send personal messages to for help!!!
BCombs
Hello. I have some issues with my Pitbull and am in need of someone who I can message back and forth who is patient and can explain things to me in English...haha.. I'm not very handy but I'm determined to get things working. My bike has been down for over three years ( partially due to a back injury and other due to financial reasons and unable to pay for things) any help would be greatly appreciated. Thanks
Dragonslave
You should probably start by posting what is the problem. Many guys on here would be willing to tell you where to start. If the bike has been sitting for 3 years, start with the fuel. Its the easiest to fix. Pull the carb and give it a good rebuild. Make sure to drain out all old fuel, pull / clean the petcock valve, and look inside the gas tank for any debris (rust, liner pcs, etc). Make sure new, clean fuel flows before hooking back up to the carb. Once you have done all this you can rule out fuel being the issue.
Then move onto your plugs and spark. I would change the plugs since they are probably old. With the plugs out of the engine, make sure they are sparking while holding down the start button. If this is working then you can rule this out.
Next check compression. I dont know a whole lot about this but do a thread search on this as it has been discussed many times on the forum.
Post back with any of your findings.
Little-Boo
Is that a no Marine?
Come on maaannnn I am always willing to help anyone. Can't you take joke, shit lets get the dog on the road. I am used to team work and that is what we do on this forum. Many on here can wrench others can't but we try to keep the dogs running just like one big family. So ask questions and I or others on here will give you ideas as to what we have done in the past to solve certain issues with these Crazy Bikes.
Lets start by letting us know what it does when you turn the key on. How old is the Battery, how nasty is the fuel, have you replaced electrical brain (EHC) or what does it do or don't do when you turn the key on. Like Dragenslave said above replace your plugs, fuel, get a good Battery if you still issued we can take them one at a time until we get this bad boy on the road again. Look at what lights are lite up on the EHC if you have one, is your Ignition Module red light on, just small things that matter.
Carlos :old2:
BCombs
K fellas. I'll be following your advice and check in afterwards... Thank you both for the replies ... I'll keep you guys posted. Thanks again
Trainguy
Chromeoholic
Carlos :old2:
